Hi all ,
I have got sony xperia L one month back and from 1st week only my phone doesnot ring when i get incoming calls. Say like i have not recieved a call from last half an hour and now i call it just beeps once, if next second i will call it will not beep even and will remain silent and on third try it will ring out perfectly. Notification ring works totally fine.
Have tried reset , latest update did not work out . Can it be due to any app or its a hardware issue ?? If hardware will sony replace ??
I am frustated with a smartphone that just doesnot ring and i miss all my calls .
Please HELP OUT of IT !!!
bro like you i am also facing this problem with my xperia L, my phone only 4 days old :smileysad:..
what we have to do??..
hey imran ,
u r from which city ? i m in chennai and these sony people are making me run all over the city for service centre .M new to city and not able to find service centre till now . If possible for u can u visit service centre and can let me know too what those ppl say.?
Thank u !!
bro i am from ALIGARH ,tomorrow i'll go to the sony service centre and tell you what did they say to me about this problem..
bro u said that you got your xperia L 1 month back so why this problem occurs now in your phone, i got this phone only 4 days ago and see i am also facing this problem..
Sorry to hear about your problem.
I suggest that you try to repair the phone software using the program PC Companion:
http://www.sonymobile.com/update
Also you can try with another SIM card to see if you notice any difference.
If the problem persists you should have your phone examined by a service center. Please contact your local support for more information:
did you guys try to use volume up, i also face the same problem with my mum phone solve it by turn on volume. maybe u guys forgot to off silent mode just like my mom. even u guys make loud ringtone but if you setting is silent u still wont hear a calling sound from phone
p/s If the volume is no sound it will change to silent mode,
Hi Alex,
I also faced more or less same issue. My xperial L is not even one month old. From today morning, sound is not working normally like when there is a call, I am not able to hear sound. When I am listening to music, sound is not coming. But, when I am connecting headphone, then everything is normal as ususal.
Please help.
Uninstall Whatsapp or nimbuzz,sumtime dese 2 apps z responsible 4 dis prblm..or update ur phone using SUS not PCC ok..
Hi man,
I have tried this b4, the phone just ring about 1 second and then no sound when calls come in.
After many trials and investigation, I found out that one of the "screen off" app is causing the problem, I uninstall the app and the problem got solved. So, I suspect that it is one of your app that caused this problem.
Don't listen to Sony's advise that ask you to reset / repair the phone, this is their "answer" but never solve any problem... if you really reset the phone, try to install one app at a time, then test the incoming call issue to pin point which app is causing the problem.
Same here bro...
What did u do to resolve this problem please share with so that I could get rid out of this problem.
