If I want to go to sleep listening to the radio on my phone is there anyway I can set it to automatically turn off after a certain period? Like you can with a television?
Thanks.
Hi @KJC13, welcome to our forum!
As @uliwooly wrote, there is no such setting in the device. The only setting is that your screen will automatically be turned off after a certain amount of time when it's not being used. (Settings > Display > Sleep).
There may however be a third party application that you can find in the Google Play store that you can use to set a timer to turn off the device. I have not used one myself so I can't recommend you one, but please take a look in the Google Play store!
Let us know if you find one that you like!
