Hello, I purchased this phone a couple months ago to replace my E4g. However since I have bought it, it has been having constant WiFi issues.
I can connect to a network fine, and the device says it is still connected fine. However, when browsing, it seems that it will run incredibly slow or completely stop, but I'm still connected to the network with full strength. This is not network specific, either - it will happen when I go out and connect to my university WiFi as well.
I have found a temporary fix which is to enable then disable Airplane Mode, then reconnect to the network. But I would like to know if this could be fully fixed as you can imagine it is a tedious workaround.
Specifications:
Model number: G3311
Android version: 7.0
Android security patch level: 5 August 2017
Build number: 43.0.A.5.79
