Can you screen record on the l1 like you can on the z5
Hi @CurryMunchin21,
There is no inbuilt screen recording in the Xperia L1 which means that you have to download an application from the Google Play store to record the screen.
There should be plenty of options to choose from if you just search for "record screen" or "screen record/recording".
I hope that helps!
