yesterday i updated my sony xperia L 4.1.2 to 4.2.2 till 24 hours it works fine suddenly it started restarting when i used to open chrome please help out
I had the same problem with a new Xperia L. Tried everything listed above, still did it. Took it to Sony Technical department. They reloaded the software, same problem. They then gave me a new Xperia L. The new phone does the same. I think there is a bug of some kind with the 4.2.2 version. I will keep on taking the phone back to them until they come up with a solution.
It happen same with me .
first phone sent back to amazon.
second phone do the same...PLUS the second phone have usb charging issue, the screen shake while charging, this is a totally hardware issue. thanks got amazon will get back this piece of s..martphone.
Only One solution stop using Chrome
goto, Setting-Apps-All-Chrome-Disable
Start using other browser like Firefox.
I Can't Believe How Could Sony Ignores This,
You are loosing Trust.
Guys i got solution
Turn on gps then open Chrome then open google And allow Access to location when it asks
thats it.
go to aps chrome uninstall updates then it should work fine
guys it's due to poor memory managemen by the os itself .chrome needs more memory to operate if the memory is full it leads to clearing of ram and eventually if the app needs more ram the system files will itself gets cleared from the ram leading to restart ,it cannot be cured just by uninstalling the updates the kernel needs to be tweaked for proper function.it's upto sony now.i have downgraded to 4.1.2 and apart from battery life and camera i'm using the phone happily with no bugs.
