It restarts only when calling or just like that. Of nothing
Se reinicia solo al llamar o simplemente asi. De la nada
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
That's probably the SIM card, could you test a different SIM card?
Hi @Jonasuaza25, sorry to hear about this.
As @uliwooly suggested, a good start is to try with a different SIM card as you mentioned that this behaviour occurs when you are making phone calls.
If you don't have a second SIM card at hand, you can ask a friend, colleague or a family member if you can borrows theirs for a short while.
To make sure that a downloaded application isn't the cause of this, you can try and restart your device in safe mode as they will be temporarily deactivated in this mode.
Let us know how it goes!
