New phone Xperia L1 Dual G3312, when the phone is turned off, the battery is charged up to 100%, when the phone is on, the battery is charged up to 60%. Charger original. What could be?
You should start by testing out a different wall charger or USB cable combinations, then depending on the results we may have an idea about the reason.
The problem was in the embedded application of Retail Demo.
