Hi. I have a weird problem. Cant update some of my aps. Just says that The app cant be updated. Try again. If the problem still arena there you can get hel with support. - 506
Anyone having a clue whats wrong? The only thing that seems to work are to remove The app and then install it again. But i dont want to do that, losing accounts etc
The other work around, although longer in process, is better.
Unmount your SD card. Then install/update the app. Restart your phone. Transfer app to sd card. Done.
Particularly helpful for apps like Amazon music, means you don't lose your downloads
Simply move that app to internal storage and try to update.
