1.i am not able to save the playlist in the walkman app. After reboot the playlist just vanishes.
2.Also with the 4.2.2 update, if have have any shortcut of an app installed in the internal memory on the homescreen , it vanishes after reboot.
Any way to get them corrected ?
Topic edited by Rickard
It also happens to me, shortcuts vanish after a phone restart.
Only happens after the new update to 4.2.2
I've been trying to replicate this here but i haven't been able to find any problem so far.
Could those of you who have this problem please send me a PM with the following information:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
SD-card (if you have one):
I have the same problem.
I make a playlist and save it.
When I turn OFF the phone, then turn it ON again, the playlist that I've saved has zero item.
There are no songs listed in it.
I've already updated, but this still happens.
Hope this would be fixed.
This happens to me but resolved after REPAIR.
I read that you had repaired the phone even though the issue occurs.
I suggest you take backup of your data, then repair your phone with PC Companion(updated).
Once it is updated do not restore your backup immediately.
After phone is updated and restarted, you test your phone by creating shortcuts, playlists..etc.,
Because, restoring or manually copying your backup may contain system files with old configuration of your phone which may be used by the phone.
So, try/test without restoring or manually copying your backup.
yes i have the same problem with my xperia J
me too looking for a solution
I have received information that our developers have found the cause for this issue and it will be fixed in an update of the phones software. I don't have any information on when the update will be available though.
