I got the Xperia L1 two days ago but it always charge until I got 60%. Then it just stops and I read that you can change it in the option but i don't know where 😕
Hi @Ariessss,
I'm sorry to this. I recommend that you try and charge your device using a different cable/charger to make sure that they are not causing this behavior.
If you are still experiencing the same behavior I would recommend that you perform a software repair using Xperia Companion to rule out that anything software related may be causing this behavior.
Keep me posted on how it goes.
