Good afternoon, I have a problem with my Xperia L1 and is that I do not ring the notifications of any application, nor WhatsApp, calendar, mail ... Could anyone give me some solution? Thank you very much.
GT
Hi @nsanchez124, I'm sorry to hear about this.
Could you test your device in safe mode and see if notification sounds are heard then? This will disable any downloaded apps in your device so you will need to test using one of the pre-installed ones.
Let me know how it turned out!
