my phone has just turned its self off and now wont come back on, help!!
my xperia L1 won't turn on , I had a charging light at first, but now nothing at all. Won't connect to pc. Screen is blank, even when charging. Please help. Thanks. AL650
Hi neilk,
I have the same problem as you had. I followed your advice but if I plug my GSM in, in my computer it starts to connect en disconnect over and over again. The connecting and disconnecting is with my charging light flashing on and off. Did you have the same problem and so, how did you fix it?
Greetings,
Jolan
had the same problem, tried all the solutions on other sites
leave the charger in overnight, hold down vol up and on button for 15 sec, etc
nothing worked !!
took the sim card out and sd card to use in my old phone, tried the not working one next day ( not been on charge ) to turn it on and surprise surprise it did 🙂
perhaps charger in ( no light was showing ) then taking the sim and sd out, then try turning on
worked on mine, good luck ….very very frustrating !!!
myG3311 wont switch on
@Leqnne wrote:my phone has just turned its self off and now wont come back on, help!!
I was on my phone and it turned it self off and now won't come on help !!
