my phone has just turned its self off and now wont come back on, help!!
hmmm i already follow the instruction above but, when im on the step under the Device software update after choosing the unit of my phone which is xperia L. the software cant detect my phone. pressing the power and volume down button are not working on my phone
Hi Sam,
I have same issue the phone doesn't start at all. While charging a RED notification light comes on. Otherwise the notification light keeps blinking but otherwise phone doesn't respond.
Holding down power button and volume up button for 15 seconds doesn't work either.
Regards,
Krishna
I have the same here, i tried one time the repair with PC software it works but again the problem back. I cannot even charging, it seems to start charge untill 2% then goes rebooting.
Actually I was trying to install custom rom on my device. When I was trying to switch on the phone it wont turn on. Even nottification LED was also not working. My phone is still dead.
i have the same issue on my xperia L after installing a custom rom.
still no solution found ?
and its also not detecting to my pc can u do something
i have L
my XPeria L looks abosolutly dead, no any reaction to charging device, no to PC, no to buttons. Pulling out/in battery dont help. No leds are reacting/working.
