- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
# When I connect charger to my xperia L, it shows charging light but battery level isnt changing.....
# And also small noice coming from charger..... (From its stepdown tansformer) i think it indicates that phone isnt charging... because that sound comes when theres no load to charge but charging led still lights...
# I replaced my charger but the problem hasnt solved.....
#IS THAT A PROBLEM IN HANDSET OR BATTERY......????????
#they given me sonyerricsson charger.....
PLZZZZZ HELP MEEEEE GUYS................
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
guys i found the solution....... its bad USB port....
it may be a loose connection between male and female ports in usb cable and phone or bad soldering in micro usb port of phone... while charging it can hear a small periodic sound from charger... it indicates that phone is not charging.... that sound dissapears after changing angle of cable little bit.... that means there is a loose connection in ports....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
It's hard to say if there is a phone problem or a battery problem. Perhaps you could take your phone to your retailer and try with another battery in your phone. Otherwise I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
http://www.sonymobile.com/global-en/support/contact-us/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There's no service center available in my country.. i bought this phone last month.. How do i check whether its a phone problem or battery problem??
i charged this phone overnight i dont kw it has damaged the battery?? do sonymobile gives me a hardware warranty??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i changed my charger and earlier that problem happend evrytime but now it happens when battery is halfly charged... here in my country we use 230V current.. is that the problem in current supply?_?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
