Junte-se e partilhe a sua experiência!
missing options
SOLUCIONADO
vickeyo7
Visitante
missing options
y there is no security question for pattern lock in xperia l after the update of 4.2.2
1 SOLUÇÃO ACEITE
Soluções aceites
Alexander1
Vencedor
Sorry, my bad.
Do you get any options at all after you have enter the wrong code multiple times?
If you don't, you can reset the phone and the lock by repairing the phone software using PC Companion:
http://www.sonymobile.com/update
In PC Companion, press start on Support Zone > Start on Update the phones software > Press the blue link that says "Repair phone".
Ver solução na publicação original
4 RESPOSTAS 4
Alexander1
Vencedor
Check which application that is listed under settings > security > device administrators. The application have disabled the pattern lock option for you.
vickeyo7
Visitante
pattern lock is working ...y there is no security question
Alexander1
Vencedor
Sorry, my bad.
vickeyo7
Visitante
is there kit kat update for xperia l
