Buenos días
Llevaba varios dias q no la reconoce, la quite y la coloque pero nada
Good Morning
I had not recognized it for several days, I took it away and put it on but nothing
gt
Hi @Macaca, let me see if I can be of any help here!
First of all, I suggest that you check whether the SD card you are using is compatible with your phone. Xperia L1 is compatible with MicroSDXC cards up to 256GB.
Secondly, I suggest that you make sure that you did insert the memory card the prescribed way into the correct slot. In this link you can find a detailed instruction as well as images describing how to mount your SD card in your Xperia phone.
Once the SD card is mounted as the description says, you might need to reboot the phone with the memory card inserted. In some cases it might be necessary to restart your Xperia phone with the memory card inserted to facilitate the detection of a newly inserted memory card.
If this does not work i suggest that you try to insert another SD card in order to see where the lack of connectivity lies. If the phone manages to find the other SD card, your SD card may be damaged and needs to be replaced
Try these measures and let me know how it goes!
