since movies is a system app, i think you cannot watch in landscape if auto rotate is off..
try mxplayer , you can view in landscape mode even autorotate is off.
As I understand there is no specific settings for this in the app so I suggest that you use auto rotate and tilt the screen to use landscape view.
Ya... can't seem to find any option for this otherwise a great great movie app from Sony.
The missing option to play video in landscape mode.. which force me to use MX Player at this moment...
(Play in background implemented... thank God and we hope this option will be there soon !)
There is a new update for movie that has the following :
Sony has updated the Movies app from build version 7.2.A.0.4 to 7.3.A.0.2. The update allows you to easily playback videos full-screen from the details page, simply by rotating the device into landscape mode. Sony has also improved the stability.
But i still need to turn on the auto-rotate right ?
