impossible to update system android
Hello,
My phone tells me that it is necessary to update the system but as soon as I try, it claims a Wi-Fi connection. The problem is that I am already connected to WiFi. Impossible to go further.
Help!
Thank you
impossible de mettre à jour systeme android
Bonjour,
Mon téléphone me dit qu'il faut mettre à jour le système mais des que je tente, il réclame une connexion Wi-Fi. Le problème, c'est que je suis déjà connecté au WiFi. Impossible d'aller plus loin.
Help !
Merci
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
What if you use Xperia Companion?
Alternatives on How to backup Xperias
