Check the cable connection to PC - XL if everything will be OK and the problem is in the phone.
You're set to MSC in the phone for XPERIA mode?
My car radio or stereo has a line in socket which using a 2 way audio jack (like the headphone jack) from my headphone socket to the radio allows me to play songs etc via the headphone socket through my radio
If you have it in MSC mode (which is the only way this will work) the content you are trying to play will need to be on the memory card not internal storage.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
