How to deactivate pattern l1
How to remove the pattern screen lock or pin from xperia l1
Como desactivar patrón l1
Como quitar el bloqueo de pantalla patrón o pin de xperia l1
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Settings > lock screen & security > Screen lock > tap on it > enter the current pin/pattern > then select None.
