if the notification LED is green that mean its at 90% or above, once it reaches 100% you will see 100% next to the battery, also your phone will stop charging, even if the LED is green, it won't charge your phone anymore.
duh..
My xperia L is charging for long time, when the battery is on 97% from there to reach 100% it is taking more than half an hour.
Any one facing this problem.
Try a force restart(power button+vol up until the phone vibrates).
Tried to force restart (power button+volume up), but phone is not vibrating and restarting as u mentioned.
How much time should i hold power button+volume up to get phone restarted.
Pressed at the same time,about 10-15 seconds.
Tried pressing at same for more than 10-15secs but my xpaeria L not restarted.
In Xperia L it seems this option is not available.You need to remove the battery and put it back in.
