How do i perform a total reset on my Sony experia L1?
@Scouse2take a look at the below link:
https://support.sonymobile.com/gb/xperial1/userguide/restarting-resetting-and-repairing/#gref
Make sure that you backup using Xperia Companion before you reset.
Hi @Scouse2, welcome to our forum!
To do a normal factory reset, please follow the instructions provided by @alexdon.
What is the reasoning for resetting the device? If you experience any unexpected behaviour, sometimes a software repair using Xperia Companion is better, as it will also reinstall the latest available software in the device, something that a factory reset does not do.
If you do not have a computer available, a normal factory reset is the only option and you can use the inbuilt backup and restore function to backup your data. Scroll down a bit on the link below and you will find information on how to do this.
https://support.sonymobile.com/global-en/xperial1/userguide/backing-up-and-restoring-content-on-a-de...
I hope that helps!
