Hello, I can not use the network anchor, I put it to share and a few seconds later it turns off and the WiFi is turned on even if it is disabled
Hola, no puedo usar el anclaje de red, lo coloco para compartir y unos segundos después se apaga y se prende el WiFi aunque lo tenga desactivado
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
restart the phone > turn off WiFi then turn on the hotspot
Vad är mitt lösenord
What is my password? - GT
Hi @Bcjn,
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
In order to find out the password for your hotspot, find and tap Settings > More > Tethering & portable hotspot > Portable hotspot settings > > Configure hotspot > Tick the checkbox named "Show password".
I hope that helped!
