En el sistema cuando me pide permisos o al desintalaraa alguna app se pone en un idioma raro y en Twitter se pone un número y después el texto
In the system when you ask for permissions or when uninstalling some app is put in a rare language and on Twitter is put a number and then the text
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Could you provide screenshots of the issue?
I would think it's a third party apps, have you installed any app from a different place other than the PlayStore
In Aptoide but was snaptube and a pdf reader
Uninstall them > restart the phone > check again, you should not risk it with third party apps
Think that the application of my telephony count as third party
