Headphones does not work
I bought a sony xperia l1 cell phone, it did not come with a headset so I tried to use a headset from another brand but there is a message saying "headsets are not compatible" I tried to restart and it worked only one way and at low volume I pressed the handset, and started to work normally I tried to use all the other headphones I had and the same thing happened. Do I have to buy a Sony phone or the phone that is defective?
Fones de Ouvido não funciona
Comprei um celular sony xperia l1,ele não vei com fone então tentei usar um fone de outra marca mais aparece uma mensagem dizendo "fones de ouvido não compativeis"tentei reiniciar e funciono so um lado e com o volume baixo,eu apertei o fone,e começou a funcionar normalmente tentei usar todos os outros fones que eu tinha e a mesma coisa acontecia.Eu tenho que comprar um fone da Sony ou e o celular que estar com defeito?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Which brand are the other headphones? do you know if they are CTIA or OMTP standard?
if they are CTIA or OMTP I do not know to tell you,the other brands were from samsung and philips
