Hello !
I have Xperia L C2105 . I had a pattern lock , wich after the phone ran out of battery just doesn't whant to let me in . I tryed google account , I tryed every solution I could find . Through android SDK , through some workarounds . Nothing works , I didn't have WiFi or mobile data on before the lock , so no solutions that require it will work .
I decided to just to a factory reset , but no combination of button holding works . I tried volume up + power , volume down + power , both volumes + power , camera + power , camera + volume up/down/both + power .
I'm desperate , i'm open to any suggestions !
Just use SUS:
http://www.sonymobile.com/gb/tools/update-service/
Charge your phone to 60% at least before.
Just use SUS:
Thank you so much !
The update service worked , I tried PC companion before and it didn't work becouse the phone was locked , so I gave up on the software side , but the update service worked great , thank you !
Anytime.
the update service doesnt work. it shows error and tells see C:\Program Files (x86)\Sony Ericsson\Update Service\workspace\.metadata.\.log.
What do i do????
What windows are you using?
Hello !
Hi, On my sony e4 e2115, when i say update software, it tells me my device is locked, and that link is bringing xperia companion, i dont know wether its the same as SUS, but when i click on the SUS link, it brings xperia companion for me.. Please help. And also the combination of power + volume up/down/both don't work on my sony!
I have Xperia c3 . I had a pattern lock , wich after the phone ran out of battery just doesn't whant to let me in . I tryed google account , I tryed every solution I could find . Through android SDK , through some workarounds . Nothing works , I didn't have WiFi or mobile data on before the lock , so no solutions that require it will work . I decided to just to a factory reset , but no combination of button holding works . I tried volume up + power , volume down + power , both volumes + power , camera + power , camera + volume up/down/both + power . I'm desperate , i'm open to any suggestions !
