hello. i bought a new xperia L but why i can't turn on the flash when i touch into the flash icon in camera apps??
I had the same problem just now: I went to switch on the torch and the button was greyed out. I managed to get it back working -
I opened the Camera and tapped on settings where my HDR was already OFF so not sure its certain to state that it is associated to whether the HDR is on or off. Anyway I switched on HDR mode then I switched it off just in case; then I tapped on the FLASH and in my Flash options (which were currently set to OFF) and I tapped on Torch which worked as the torch came ON and then I selected auto flash to turn it OFF. I closed the Camera and rechecked my Torch Button which was no longer greyed out and was working again. So the problem does seem to be associated with the Camera somehow
