Does this phone have wifi calling
Hi @Porncrumpet1, welcome to our community!
The Xperia L2 supports Wi-Fi calling, but there are some requirements that needs to be met for it to appear in the device and work.
I would recommend that you check with your operator if it is supported for the Xperia L2 in their network and they will also be able to provide information if the device has to be bought from them to have it working or not.
I hope that helps!
