do i need to off stamina mode when im charging?
or i will let the stamina mode ON during charging mode?
how to proper charge? ON or OFF the unit?
pls help me!! sorry for my english
You can leave stamina mode on even when the device is on charging
The STAMINA icon on the notification bar is turned off automatically when the phone's charging.
So I don't thing you have to switch it off manually
it doesn't matter if you have the STAMINA on or off when you charge your phone, the same goes for airplane mode, or playing games or using your phone while charging it, just like anything else, if you use your phone while charging it will take longer, if you charge your phone through a computer it will take a LOT longer than using a wall charger.
I own a Z3 Compact. And when the device is charging STAMINA is not turned off automatically. How to fix it?
The charging time should be the same.
