I just updated my phone o 4.2.2 and facing some serious issues out of which the most annoying one is while dialing a number from contact, some ZEROes are getting prefixed to the dialed number and call not getting connected, then I need to delete those zeroes and dial it again to get connected, can anyone help me out here, this issue is really annoying
One more serious issue that I'm facing is on lock screen, some times the lock screen is blinking.
I think I solved it, that was an issue from the application 'tawkan' , I just uninstalled it and now its OK
