How do I delete a folder in the album that I've made.
It's probably something stupid I haven't noticed yet.
But I don't know how
#xperial1
@Alec_ you need a file explorer to see the folders inside your internal memory or SD card.
Hi @Alec_ ,
In addition to what @alexdon mentioned, you can also delete the a folder by deleting or moving the entire content of the folder to another folder, for example 100Andro. If you want to move the content to another folder, open the folder that you want to delete tap the three vertical dots in the top right corner > Tap "select items" > Tap the three vertical dots again > select all > Tap the three vertical dots again > Tap move to > Choose folder.
After the items has been moved, the folder that you accidentally made should be deleted.
I hope that helped!
