- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hey everyone here can you help me how to set up the NFC settings?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Under 4.1.2 extended length APDU support over NFC worked like a charm. Now with 4.2.2 "Transceive errors" occur everytime an extended length APDU (longer than 261 Bytes) is to be transferred. Seems someone put in old drivers (libpn544_fw.so) and/or old Nfc.apk.
This renders the phone finally unusable when you're using intelligent RFID chips for authentication.
Bad update.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Found it. You guys put the wrong (old/broken) libnfc.so into the Android 4.2.2 update. Taking the old one and exchangig that makes the phone working again. BTW: The Xperia M can be modified the same way. My SP, Z and Z1 have to small antennas to give useful test results with our tags.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
bt after updating it to 4.2 it stopped wrking.
is dis a hardware problem or software issue?
thanks in advance
- « Previous
- 1
- 2
- Next »
