How do i find blocked numbers on my Sony Xperia L1
Hi @Bluehonda, let me see if I can help out here.
In order to find out which numbers are blocked on your Xperia L1, find and open the phone app > Tap the three dots in the top right corner > Tap Settings > Block number. After doing this, you will see a list of all blocked numbers where you are able to add or remove numbers from the block list.
I hope that helped!
