I took of my battery and let it out for 1 night, and then everything is ok, but before, near the battery indicator was a battery percent, now its gone and i have no idea how to put it back. Please help
Please try this:
Now you problem is solved.
Thank you very much. it was checked but i unchecked it and then check it away and now its working. thanks
I don't know why, but as long as it is working fine, I think it is okay.
You're welcome anyway.
I have one more question:
When i move a song from a folder to another, it sometimes give me 2 songs in walkman app, one is working but the other has 0:00 seconds and i cant remove it neither from the walkman app, nor from the file manager.
I don't know why that is happening to you. But I think you can try to remove it from your computer. Anyway, please check on the existing thread about that, and/or create another thread with different subject, so the other can help you correctly.
Dear friend,
I have the same issue on my xperia z1, its not showing any battery indication on the screen. Even the charging time also.
I checked over the power management, but noting for the indicators
So please answer me????
