الهاتف لا يوجد به تطبيق مذكرات وهوا امر غير جيد بالنسبه لي.. بعد اذنك ممكن اسم تطبيق احمله من المتجر.
ما الوقت المناسب لشحن البطاريه وما الوقت الذي ينتهي منه الشحن؟ شكرا سوني
The phone has no application notes and hwa is not good for me .. after your permission is possible to name the application to get it from the store.
What is the time to charge the battery and what time does it end up charging? Thanks Sony
GT
Hi @Gomaa1, welcome to our forum!
There are plenty of different applications for notes that you can find in the Google Play store if you search for "notes". Some of them have the ability to synchronize your notes to for example, your Google account so you can edit / view them on multiple devices.
According to the environmental document for the Xperia L1, it takes 3.8 hours to charge the phone from 0% to 100%. Do note that this is only valid if the phone is powered off and you are charging it using the wall mounted charger that was included together with your phone.
I hope that answers your questions and let me know if you found an application that you like!
