How do I get my experia to light up when I receive msgs
Are you referring to the camera flash? if you are, you will need a third party notification app to do so.
Hi @Callum11, welcome to our forum!
Do you want the display to turn on when you receive a text message? This is not a standard function in the Xperia L2 or in the pre-installed Messaging application, but you can always take a look in the Google Play store and see if there is any other messaging application that has a setting for this.
I hope that helps!
