Hi.
My soundbar is playing up. When I plug my STB in the sound bar and then the sound bar to the TV I select HDMI, the led lights change on the soundbar to flash TV and USB. Nothing is displayed on the TV. Can't even get into the main menu.
Has my soundbar had it? Gutted. 😡
Here’s the manual for your soundbar:-
The word flash occurs 47 times; do any of these explain what you are seeing?
This one (page 53) looks promising:-
Depending on the order in which you connect the TV and the system, the system may be muted and the TV and USB indicators flash slowly. If this happens, turn on the TV first, then the system.
Hi sckeebl, was it ever working fine before?
