I have a s370 blu ray player and also have the uwa-br100 dongle. I set it up initially and it worked a treat. Left it for a week and it disconnected and took many attempts to connect it again and then downloaded the latest firmware update. Left it again for a few days and the same happened except this time after countless attempts over several days it refuses to connect. It finds the router (100% signal and no security) and the dongle but refuses to connect. I've tried every re-set I can think of but to no avail. Can anybody help?
Hmm - maybe the dongle is faulty? I would try and get it exchanged or maybe swap it for some homeplugs?
thanks
