I have a KDL-40S4000 Bravia with a DAV-DZ260 home cinema system. I would like to get SMP-N100 to play video files from my external HDD without having to burn them on CD or DVD (as I have to now). Will I be able to connect it to my current setup? If yes, how? I'm afraid I'm not a very technical person... :smileyblush:
Yes - HDMI cable from the N100 to your TV, optional optical cable from the N100 into your Z260 which will give you surround sound. You can then either stream files over DLNA to the TV using the N100 or like you say connect a Hard Disc Drive to the device.
Thanks
Thank you! Much appreciated.
