Hi
I bought a Sony HT-SF150 soundbar, but due to the organisation of my room, I need another speaker to broadcast the sound to, so the sound will come from both the soundbar and the other speaker.
Does anyone know of any speakers that I can definitely connect to this soundbar, that are easy to connect and also aren't really expensive.
Thanks
You can't add anything to the soundbar, it is not an AVR
As @rooobb says, you can’t connect anything extra to the soundbar, but assuming you are running the soundbar via ARC, you could connect one of these
https://www.sony.co.uk/electronics/televisions-speakers-speaker-grilles/srs-lsr200
to the TV Optical Out, and position it wherever you wanted in the room.
Okay thanks.
I thought I'd be able to add some kind of bluetooth speaker i.e. broadcast the sound over to the bluetooth speaker. Is that not right?
The soundbar only receives Bluetooth, it does not transmit it:-
You could certainly hang an Optical to Bluetooth converter on the Optical Out of the TV (Amazon have a selection of these for a very few tens of £’s) and send audio to a separate Bluetooth speaker that way.
But it will have to be very low latency, like the Sony unit above, if it is not to lag the audio from the soundbar, and you will need to be sure it is in phase with the speakers on the soundbar (i.e. that the cone(s) in the Bluetooth speaker move out when the cones on the soundbar speakers move out, and not in, instead, or the sound will be all disembodied and strange).
Okay thanks for the ideas.
Could you explain about the "low latency" that you mention - how do you tell if a speaker has low latency and are there certain ranges etc?
Thanks
Imho you cannot. The result will be always bad. It is like that even if driven all directly by the tv (like lg ones that can handle BT and internal speaker at the same time), let alone if one is driven by the soundbar connected via arc and the other via optical and bt transmitter: they will never be in sync
Hey theoportoman, this one doesn't support adding speakers. Also, the suggestions on this thread aren't guaranteed.
Thanks for that.
Can you please then explain where Sony’s claims for the SRS-LSR200 depart from reality?
@HannahEd01 Hello - also keen to know this. Am trying to find out if it's possible to use a soundbar and also an SRS-LSR200. I currently have a set of wired speakers and an SRS-LSR200 both connected (via a headphone jack splitter) to the 3.5mm headphone output at the back of my TV. The wired speakers are on their last legs and I'd like to replace them with a soundbar - but want to check I'll still be able to use the SRS-LSR200?
Thanks in advance!
