Hi friends:
My projector suddenly turns off and two red lights starts flashing 5 times each time, then I turn the projector on again it works for 1 minute then turns off and the red lights start to flash again 5 times.
does any one knows whats wrong?
I did clean the projector and the filter but still same problem.
Thanks
Hi there,
As this is a Sony Pro product I would suggest getting in touch with the Sony Pro team here for further help.
Best wishes,
Sean Mc
Hello!
I have exactly the same problem with this projector! Did you manage to fix it? What was the issue with it? Thanks!
