VPL-HW45ES Product Registration And HDCP
Greetings all - I have 2 simple questions:
1) Which version of HDCP does the Sony VPL-HW45ES support?
2) How can I register my Sony VPL-HW45ES? The options are only Sony VPL-HW40ES and Sony VPL-HW55ES. It skips my number in the middle on the registration page!
Background Information:
I have a Humax FVP-4000T and I use it with Netflix and the above projector. However, on certain movies (like Warcraft) the resolution is only 480p. I've contacted Netflix over this and they say it's because there's an issue with HDCP compatibility. I'm not sure I believe this, as Blu-Rays play beatifully on the projector.
2 REPLIES 2
Anonymous
Not applicable
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
profile.country.GB.title
Vanilla_
Contributor
Hi MartinSony2017,
I've checked your projector model, and i was able to locate it only on Sony US website. I guess this might be the reason why you're unable to register it on the website of Sony UK.  You can contact the US support team to check this.
Thanks,
Vanilla_
