My BDP-S370 is not near my router to connect a LAN cable and I do not have a wireless adapter on the player.
Is it possible to download the updates and burn them to a disc and upload the update to the player from the disc?
Or, I have a laptop that is wireless to my router, can I connect the BDP-S370 to my laptop and update via the laptop. If so, is it just a case of connecting with a LAN cable or HDMI cable, or does the laptop need software?
Apologies if I'm asking the obvious, but this is the first time I've attempted something like this.
Message was edited by: tonyward278
Thank You for the link, exactly what I was looking for but my search did not find it.
Everything updated and verified,
Thank You
