For some reason, I am unable to play my music or in fact any files via my BDP-S790.
I am using Windows 7 and media player to share the files over homegroup....my computer is detected on the BDP but for some reason only under photos and video NOT music. Even under photos and videos it is still unable to recognise any files.....VERY frustrating....if I can't solve this quickly the player is going!
Hi there
I cant comment on using media player, however what you can do is try another piece of software called Homestream and see how you get on with it.
http://www.sony.co.uk/homestream
hope that helps.
its not the player at fault but more a file limitation with media player, i would do as Quinnicus suggested as Homestream (or Serviio) is far better, i use Serviio myself with my tv and my 790
