Unable to connect BBC iplayer on Sony BDP-S370. All other internet channels connected. Lovefilm, Five etc. Can anyone help? It says server not responding
I believe the issue is more BBC related.
Please check out:
https://www.sony.co.uk/discussions/message/616391#616391
Cheers,
Nico
Hi saburns78.
It's a fault that all Bravia TV owners are experiencing at the moment also check the Bravia threads on this MB. Just need to hang on till the Sony IT guys go back to work on Monday
I too am unable to connect to the BBC iPlayer on the BDP-S370. All other Internet services are fine, and no, I don't have a Bravia TV.
The cause of this error was the recent Network Update. I suspect that you updated your Blu-Ray player like me the other day. Unfortunately, it ain't recommend to 'degrade', so I suspect a patch soon.
Hear me Sony... soon. You should do my beta testing before releasing updates.
Please check out:
Cheers,
Nico
