When I try to play music stored on a NAS drive it plays album tracks in alphabetical order and not track number order.
Is this just how it is?
Hi Dean
It's possible there are track listing options, hopefully someone will have had the same issue in the past and found a solution.
Are you using an app of any kind?
Mick
Just using the display on my TV and the Bluray remote. Had the same issue with my Panasonic player. Sonos works okay though.
