I have a brand new UBP-X700 connected to an LG 43UK6300PLB.
The picture randomly keeps going black for a second or so.
Highly annoying.
Yes it has the latest software update.
Also i can't get back into settings as every time i press the "Home" button it seems to lose it's connection to the TV.
Seriously unimpressed.
Hi @babysnakes33, welcome to the community.
This is often a conflict with the HDMI 'Deep Colour' or frame rate settings. Have a look at this article and see if something there works.
Mick
Many thanks Mick.
It seems buying a fast HDMI cable "does" actually make a difference!
Using the new cable allowed me back into the home screen to do a "reset all" and now it's playing discs with no problem & the mechanical buzzing sound has miraculously vanished as well.
As far as the Deep Colour is concerned my TV automatically turns it on, now with no problems.
Thanks again for your reply.
