Hi all,just looking for some advice please....
i run my sony tv through a sound stage HT XT1 for regular tv.but for movies i go through my surround sound 5.1.
Now ,iv'e just updated my recevier to an STR DN860 ,and i use a logitech harmony ultimate remote to control everything.The problem i getting is when i switch on the reciever with the remote the sound bar also starts up,is there away of changing the signal to seperate them?
You sould not need any all-for-one remote to command all those sony equipment, yshould be able to command everything from the tv remote (BTW you should give also the TV model). In any case you can switch off Bravia sync completely on the TV or just switch off the power-on/off feature in bravia-sync
