Hi I'm new here so be patient with me!
I have a KDL-42W705B Television with a SVR-HDT1000 DVR and a BDP-S185 Blu-Ray player. Attached to this system is also an Apple TV (Model A1427) So far everything is fine.
Then I bought myself an HT-XT3 Sound Base. That's when the fun started! The sound base would work intermittently. Sometimes dropping out and in and other times not working at all. I have now removed the DVR and all appears to be working normally. Any ideas on how to make everything work in harmony or has anyone else had similar problems?
Hi there
I have had similar experiences with my HDT-500 connected to my Sony AV Reciever. Unfortunately with all my tinkering, i have not managed to resolve it.
When I have my HDT-500 connect, on many occasions at first switching on the TV and systems, i get absolutely no sound. I have to switch everything off and then on again, and then all will work. Removing the DVR, i have no problems.
The problem appears to be a HDMI handshake connection issue. I cannot remember if this works, as it has been a long time since i tested it (i rarely use the DVR anymore, as i dont have it perminently connected), but try switching OFF, the 'Control for HDMI' in the settings of the DVR. You will loose the ability in using a single remote though, so you will neef to use the remote control that came with it.
Other than that, ive not found a proper solution im afraid.
Thank you so much for your reply! Very reassuring to know that you have had a similar problem. I'll try your suggestion later if I reconnect my DVR.
