have a svr hdt1000 with just a continuous flashing blue light on recorder and HIGH DEFINITION HARD DISC RECORDER on tv connected via hdmi lead. i have tried hold in the reset button under front flap, as well as holding in front power button while connecting power supply to the unit so i cannot do a software update. ANY IDEAS would be much appreciated as i have now run out. Thanks Garry
Hi there
If you have tried pressing the reset button (with a pen) for about 5 seconds and still did nothing - then the only option is to leave it completely disconnected from the power over night and fingers crossed it works. Also check and ensure that the HDMI cable is fully connected on both the HDT1000 and your TV and maybe try another HDMI cable as well. (it may have dislodged itself).
If that fails, im afraid it will probably need a repair - if economically viable to do so.
Thanks for your reply but i have tried all your suggestions still no luck, i think it will be a trip to the tip for it`s last resting place but i really appreciate your advise. Garry
You;re welcome
It does seem like a hardware issue though, as the constant flashing light indicates this.
